Royal Scribe
Royal Scribe
Royal Scribe
9,534
Member
3,353
Birthday
February 5, 1968
San Francisco, California
Website
Real Name
Kevin
Mapmaker
16
  • [WIP] Community Atlas: Kumarikandam - SE Tiantang Region
    Here is the basement of the temple:
    Toggle: SECRET layer to show/hide the secret passage escape route.
    Although trainees and junior monks live in barracks on the monastery’s grounds, the more senior monks have quarters in the temple’s basement, where trainees may join them for the final meal of the day. The basement also includes a kitchen and a crematorium, which share a chimney that rises outside the temple on its northwest side. Senior monks are interred in sarcophagi in the temple’s crypts when they pass away, but trainees and junior monks are cremated, with their cremains interred in urns in a columbarium.
    A circular room that connects to the crypts is used for funeral services and other rituals. There is a teleportation portal here that the senior monks can use to access the Zhao Guang Si’s Trials of the Elements. Trainees who survive those trials will be teleported where upon completion of all four trials.
    LoopysueRickoJuanpi
  • [WIP] Trying to design a barrel roof
    It looks good! First I tried it with 10-foot wide, 10 degree pitch increments, with a 80 degree pitch at the edges, working up to a 10 degree pitch at the center. The transitions were a little sharp:
    Then I redid it with a more gradual transition, 5-feet wide sheets with 5 degree pitch increments going from 85 degree pitch at the edges to 5 degrees at the center. That worked much better! Some fill styles worked better than others, of course -- though some that I didn't care for might be improved if I play with adjusting the scaling. Roof tiles didn't really work very well, but wood worked, as did different stone fills. Here are the top 50% of my experiments:
    Thank you for the tip, Sue! I can play with fills (and the scaling of those fills), but I feel like I have something solid to work with here.
    RickoCalibreGlitch
  • [WIP] Atlas Contest (potentially) - Arbor Hollow (summer, autumn, winter, spring)
    Ooops, just noticed that I overlooked a change in Spring that I had intended: changing the farm fields to just furrows, since it's spring and the crops were just planted and wouldn't have come in yet.
    QuentenLoopysueGlitchRickoShessar
  • [WIP] Rise of the Crone-Mother
    Here's the inside of ones of the hag's caves. Outside, you'll see her cauldron over a fire pit along with some gruesome trophies: skulls and scalps on pikes. (Also added bed a of fungi outside). Bones dumped in a heap in the opening area. "Bedroom" area off to the left -- the bed is just a pile of dried leaves. Some cells for captives (fresh meat!) with grasping vines to keep captives "shackled" and carnivorous roots barricading the doorways. And in the middle, steps going down...
    Oh, and I reduced the opacity of the drawn shadow to 40%, hoping that will make it less "floaty."
    QuentenLoopysueRyan ThomasRalfRicko
  • [WIP] Haunted Mansion
    Round 3! These fog symbols are scaled at x4.
    MonsenLoopysueseycyrusRicko
  • [WIP] Community Atlas - Rhaghiant (western Doriant)
    Okay, here's a first pass at the portion of the map I've adopted for the Community Atlas. This was done using the Spectrum Overland style. So far, this is mostly just terrain converted from the parent map.
    I want to add more individual trees around the edges of the forests where they look too squared off. I still need to add rivers (this map only came with one in the bottom right), and if necessary, more hills or small mountains at the source of the rivers.
    This map came with five settlements. At this scale (each grid square is 100 miles), should I keep the beveled dots from the parent map or use the lovely Spectrum Overland symbols? I created a diamond-shaped one (on the larger island) for other points of interest. (I'm thinking that island may be a resort playground for the rich and famous, like a cross between Monte Carlo and Las Vegas, that operates outside of the reach of the country's law enforcement.)
    I wasn't thrilled with how the savannah/grasslands blur into the desert on the right. I may need to adjust the sheet effects. I also thought about encircling the desert with dunes. I did it half of it that way so you can see it with and without the dunes. Thoughts? Oh, and I need to add some saguaro cacti or joshua trees.
    I'd like to add a swamp somewhere. I plan to add a henge at one of the northern forests, surrounded by more trees -- that's where elves live. And a dwarven fortress in one of the southern mountains.
    Roads will come last, once I've determined the rivers, major settlements, and points of interest, and then need to connect them.
    Advice welcome, including the name.
    QuentenLoopysueBwenGunGlitchCalibre
  • [WIP] Community Atlas Competition - Artemisia - Verinress Arl - Fon'Anar
    I finally have a bit to show for my contribution to the Community Atlas Competition. More work is needed but it's enough to provide the gist.
    I adopted a little farming village on the edges of Verinress'Arl on Artemisia. The parent map's notes explain that Verinress'Arl is populated by Aeifa (surface dwelling drow), who are ruled by a Matriarch, where succession is by fight to the death among her female offspring. The red box here (northeast of center) shows the village in relation to the rest of the kingdom:
    The village was once the site of a military outpost, but when it was decommissioned generations ago, a village grew up and took over some of the surviving military facilities: a small fortress that became the village jail, and a tower atop a hill that was purchased by sorceress to live out her years of retirement. The tower was passed down to one of her apprentices, and so on through the generations.
    While the villagers are mostly self-sufficient, raising enough of a variety of crops to sustain the village, it's known for its fruit orchards and even more for its vineyards and the wines that are popular throughout the realm.
    Here's the village so far (I also put a copy in my gallery if you want to zoom around):
    Still more to add within the area protected by the palisades, and forests to the north/northeast.
    Here's a closer view of the hillside known locally as "the rock" (though a proper name will be provided on the map):
    In addition to the sorceress' tower on top of "the rock," there are three other buildings the dig into the hillside. On the south/southeast, a decommissioned military fort has been converted into facilities for the village watch, with jail cells built underground in the hillside. On the eastern side, the Temple also digs into the hillside where the crypts and religious records/artifacts are maintained. And on the north side, the winery (which may be a bit oversized, now that I see it) also extends into the hillside, where wine can ferment in giant vats in caverns protected from the heat of the sun.
    The government buildings include the City Clerk's office in the center, with the courthouse to the east, the mayor's office to the northeast, and the town council chambers to the northwest.
    Here's an example of treehouse housing. More smaller complexes like this will be built elsewhere within the palisades.
    Outside of the village walls on the southwest side is a large pond. There are some industries along the creek that exits the pond: a small mill, blacksmith, tanner's, and glassblowers. North of them is a hillside and field that have become an entertainment area. A large bonfire is lit most warm nights, where the villagers make music and dance. There's also a stage where traveling minstrels, troubadours, and traveling acting troupes can perform for the villagers who can sit on stone benches before the stage or on the hillside behind. The big building on the northeast side of the pond is the community baths (elves are stereotypically fastidious, after all).
    Much more to come, but since it's officially August, I wanted to post what I have to date to start getting feedback.
    QuentenAleDLoopysueRicko
  • The Sola System: Adnati's star and celestial neighbors
    A few tweaks, including increasing the size of the wormhole and adding a glow.
    LoopysueRalfMonsenWyvernRyan Thomas
    Made some good progress, including labeling some of the primary businesses and points of interest. I also widened it a bit to make room for a legend. The text was a little hard to read so I added a semi-transparent back. Let me know if it's still too hard to read, and what you'd recommend to help that (make the back less transparent? darker or lighter shade?)
    LoopysueMonsenQuentenJuanpi
    I just noticed that although I posted my completed map in the competition thread, I didn't post an image of it here. Doing that now, just so this thread shows the full process.
    I have wanted to use Mike Schley's elven treehouse symbols ever since I started mapping with CC3+, so I am delighted to finally have had the opportunity. (My friend keeps calling this map -- especially because of the elevated pathways -- my Ewok Village.)
    LoopysueQuentenroflo1
