Quenten
Quenten
Quenten
8,062
Member
3,090
Birthday
November 29, 1950
Australia
Real Name
Quenten Walker
Mapmaker
16
  • IDEA: Terrain over cutout rivers
    What a great work around - thanks @Royal Scribe
    Royal Scribe
  • mirror/flip a poly ???
    Click on Edit>Reshape>Mirror, then select what you want, then draw a line of the axis you want it flipped around. Not sure whether you need a mouse for that though, Helen
    Don Anderson Jr.
  • Birdseye Continental - style development thread
    Perfect ridges - I really love that Sue. And it allows for different terrain types to be shown as you have got here. So, grassy, rocky, volcanic terrain will also show through. I really love that.
    And sure, if you draw 8 sided snowflakes, then your drawn snowflakes have 8 sides - someone should tell the real snowflakes to get with it and advance to 8 pointed flakes - lazy things.
    Royal Scribe
  • [WIP] Community Atlas: Kumarikandam - SE Tiantang Region
    Hi, Ricko. I think the farm fields are a bit TOO large, especially given the scale. I would reduce them by reducing the scale dimensions in the Bitmap menu. At least, that is my opinion, and I accept if you don't go for it.
    I absolutely LOVE the write-up. Very oriental mythos.
    Ricko
    I always have specific Terrain sheets for different biomes on all my overland maps - i add them myself. So I applaud what you have done here.
    Royal Scribe
  • Installation of new monthly content - Fractal Parchment Worlds
    Same here, but I was able to access it via the subfolder in the Annuals folder in the CC3+ intallation on the System Data folder on my drive that i installed CC3+ on.
    EdE
  • What's your favourite overland style?
    I am going to exclude top down styles.
    So I use Schley mostly, but I don't think that should be the one because it already has so many symbols.
    That leaves my next two equal favourites - Jon Roberts - but few too symbols for me to use often; and Spectrum - which could do with a heap more symbols, but it is alone in depicting grass covered hills and even mountains, which I really like. That is a big omission from Schley - hint to the monthly freebies from Schley
    I also forgot to add that Spectrum has by far the best fills. I would urge that ALL the Koppen biomes are included - with perhaps at least 2 fills per biome.
  • Advice for planning a major city?
    I am a bit puzzled by the comment that raster as opposed to vector slows things down. My experience is the opposite, as I guess Sue's is too. So my tip would be to keep vector symbols to a minimum. But I am open to correction.
    Royal Scribe
    If the population is above 20,000, I use the following rule of thumb to work out size. On average, each building has 30 x 30' (or 10x10 m) footprint, with 2 stories. Each 100 M2 houses 4-6 people, thus on average, each 100 m2 houses 8-12 people. So the formula for distance (in square Metres - I just cannot think imperial - we have been metric since 1970's) is Area = Population x100/ people in each 100 m2/ number of stories per building.
    So, if you want a sparsely populated city. make it 5 people per 100 m2. Say the population is 50,000. For all single storey buildings of 100 m2 average, that is 10,000 buildings requiring 1,000,000 ie 10,000 x 10,000 m in area.
    But make the city more densely packed, say 10 per 100 m2, with average of 2 stories per building, and the area required is greatly reduced. Area = 50,000 x100/10/2 = 250,000 m2, or 500 x 500 m2. Add some extra for very large buildings, and you get an idea of the dimensions required for your city - but remember to add extra to make room for space outside the city walls, or building extents.
    In general, for a 50,000 city, I would allow about 1000 x 1000 m dimension (or 1 sq km).
    Dun Fingolfin has 16526 buildings, and dimensions (of the city, not the map) of about 6600 x 3100 ft (yes, I used feet for the Atlas to fit in with all you imperials) which is about 35 x 35' per building (close to 10 x 10 m) with average of 2.5 stories per building, and a dense population of 10 per 35x35', that gives a population of Dun Fingolfin of about 413,000. But if I had made it a sparsely populated city with average of only 1.5 stories per building, and only 5 people per 35x35 ', the population would be only 123.000.
    So decide what population you want, how many would fit into a 100 m2 space (you will have to work out what this is in sq feet), what the average number of stories per building is, then that works out the number of buildings (Pop/ number per 100m2/average stories per building) and area (no of buildings of 100 m2 average x 100) in m2. Hope this helps you gauge your area and buildings required.
    Royal Scribe
