Quenten
Quenten
- Quenten
- 8,062
- Member
- 3,090
- November 29, 1950
- Australia
- Real Name
- Quenten Walker
- Mapmaker
- 16
Reactions
Ukadarlia
The Aeifa - 'elves' of Ukadarlia. These really are just a human variant, though more so than the other human ethnic groups. They have purple eyes, and can see into the UV range; they nearly always have red hair; and are very tall and very thin. They have extended life spans up to 300 years, due to biochemical changes that slow aging.
WIP: Bleakmoor Harrow - Continent of Estonisch
OK, then if that is the case, nothing needs changing - though perhaps the open areas need explaining. Google maps shows the true density of the Amazon, and the open spaces are either economic activities or settlements or tribal lands (though the latter are also quite densely covered with forest).
This is just one aerial view of the Amazon - so if anything, your jungle is less dense!!! LOL
Hardin Region (Myirandios) - Isle of Kalihirin, and Isle of adventure for low level characters.
Here is a setting for a series of low level adventures to get a beginner D&D party on its way to fame and glory ... or grisly death.
Kalihirin Island (nowhere near complete, of course). Of course, adventure sites etc are yet to be added.
Detkhiv, the main settlement with a population of over 600.
I have made use of the draft version of the Watabou revised city annual to come later this year.
Hardin region of Myirandios
Community Atlas - Irisian City States - Tiresia City State
Community Atlas - Irisian City States - Megalith island
Interesting Political Take on the Mercator Projection
[WIP] Marine Dungeons Lighthouse (more May Annual Stairs & Steps)
Community Atlas - Irisian City States - City of Tiresia using revised Watabou.
Here is my version of the city of Tiresia, using the forthcoming Watabou Cities revised annual coming out in July.
I discovered one further problem with the drawing tools being applied to the imported DXF. Regardless of the import parameters, the walls remain as 2D polygons. The work around is to use the break command on each section. Click on the icon labelled x,y in the left hand of the screen, and select the object. Untick closed.
Then apply the drawing tool. This is the method I used.
Alternatively, just use the tool to draw the walls along the lines without using Change Like Drawtool command, which is probably easier. The lines will be removed when you delete the IMPORT sheet at the end of the process.
This is the result, for a fairly big city, using the Change Like Draw Tools command only.
And after a few alterations, I am designing the city more to my liking and fleshing out the surroundings, redoing the fields using the Drawtools to get field furrows aligned automatically with the fills from Sue's Darkland City. Did a demolition job to erect a large amphitheatre/football ground.
