Quenten
Quenten
Quenten
7,222
Member
2,875
Birthday
November 29, 1950
Australia
Real Name
Quenten Walker
Mapmaker
16
  • Tatilana - Western Sergeevna
    And the female. The race is supposed to have black hair, blue eyes and red skin, suitable for the tropics. Tall and slim.
    LoopysueJimPLoreleiRickoLauti
  • Ostralura - north-eastern region
    Sylarlir - Aeifa Queendom
    Veisterlitz, another impoverished Dreschleben Autarchy
    And the Woolloo and Cambalong Tribal areas - Wal'loori clans. Also showing the two Davarin (Dwarven) fastnesses of Karaztor and Nalak Dum
    JimPRickoRaiko
    The area I am concentrating on, the Mimburi-Imarbara region
    And the same region done in Ellis's watercolour style
    JimPRickoRaiko
  • [WIP] Community Atlas Competition - Artemisia - Spiros Isle - Aretizo village
    Slow progress. Here is the village as a whole to date, and the west quarter - Grimy Street, with the heretic (who is on the execution wheel) house which has been burned to the ground by orders of the kind gentle merciful Monks of Holy Spiros. (so glad nothing like this happens here in real earth).
    Royal ScribeMapjunkieLoopysueMonsen
  • Myirandios - Hardin Region - Skalamark
    Here is the northern part of Skalamark. I made free use of Norwegian place names, some Norwegian translations, and the Viking symbols from Mike Schley latest monthly offering. I hope there are some more to come, for use in this hardy land - rather like Harald Hardrada's kingdom.
    Royal ScribeMonsenGlitchLoopysue
  • Watabou City REVISED (annual 157)
    I have now converted all the IMPORT into the appropriate sheets using the Change Like Draw Tool Command only.
    Remember to set the correct Sheet and Layer for each Change like Draw Tool command.
    eg Rivers and Seas (Lakes): Sheet WATER/RIVERS, Layer Water/Rivers
    Roads and Squares: Sheet ROADS or ROADS PAVED, Layer Roads. Note that Square Paved cannot be used in Change Like Draw Tools since it has a macro attached. I may change this later if I can find a paving that doesn't need alignment.
    Parks: Sheet PARKS, Layer Vegetation.
    Docks: Sheet DOCKS, Layer Docks
    Walls: Sheet WALLS, Layer Walls (Note: I have done away with the City Wall Layer). I am still not happy with the crens for the walls - now they hardly show. I will fix that.
    Towers: Sheet TOWERS, Layer Walls. No longer need to draw these without the Change Like Draw Tools command. And it means no guessing as to the size required.
    Bridges: Sheet BRIDGES, Layer Bridges
    Fields: Sheet FIELDS, Layer Vegetation. The furrows align to how the generator drew the fields. So often, not a very intuitive direction. However, if you want to use the tool directly to draw fields, the tool does align the furrows (which are Hatch symbols) correctly. In the picture below, I have done this with the bottom right hand field.
    Buildings: Sheet SYMBOLS BUILDINGS, Layer Buildings, or any of the Building layers you wish to use, eg Bldng (House 1)
    I generally advise doing the Buildings last, as you can then Hide all sheets except Import and Symbols Buildings (with the latter being the selected one). This will then show only the buildings you need to convert.
    I have also added buildings on top of the Palace, and smaller towers on the towers around the Palace.
    Comments and suggestions really welcome.
    Royal ScribeMonsenCalibre
  • [WIP] Isometric city
    This is the very first time I have done anything perspectives or isometric. But I was inspired by Ralf's recent video, and the current Annual issue, so I decided to give a big city a go.
    Here is my initial layout - cliffs, main roads, coast and walls done.
    One observation - the walls look a bit artificial with the straight parts and only 4 directions. But I hope that will not be so obvious once I add vegetation and buildings.
    Comments, as always, welcome - you can only help me get better.
    LoopysueJimPRickoHadrianVILauti
  • Ukadarlia
    The male and female Norvians - rather pale green-olive skin, mediterranean types.
    LoopysueJimPGlitchHadrianVI
  • Ukadarlia
    The Kratirim - a Slavic -like people
    LoopysueGlitchRickoMonsenEukalyptusNow
  • Community Atlas - Kumarikandam - Northwestern Tolgad
    Here is another map for the Community Atlas, in a style I have not used before - the Myrklund style. I like the jungle trees, and have used them before (especially to indicate mangrove swamps).
    Text to come, after I have cogitated on the map a bit more. Comments and suggestions welcome.
    Royal ScribeMapjunkieJulianDracosGlitch
