Frosty
Frosty
- Frosty
- 160
- Member
- 148
- Surveyor
- 2
Reactions
1920s Town
Arkham House Basement
The Start of my Arkham House Basement. The main room with bookshelves is suppose to be a museum where I will display artifacts the group(s) they have found over time.. and maybe figure out how to link it in Roll20 to actual handout that describes the item. I hope to figure out how to take an image and turn it into a symbol that I can put on the tables or bookshelves.
Arce Ursi
Mars Ultor
The redone map has gone over rather well. The Columns using dynamic lighting look fantastic and give the place a lit but of an eerie feel to it which was perfect. Photos here I used for atmosphere and to describe the ruins on the service at Mars Ultor. I used the modified map for below ground ruins..in what I claimed was an older version of the temple that sunk in early 300 AD.
Here is a small outside area of the map with dynamic lighting in affect. I think it gives a decent impression of what the players could see. Keep in mind what looks like a shadow here was an area they could not see at all.. so something could always be lurking behind a pillar.
Added custom symbol for found artifacts and added them to the basement tables but thinking I may remove them and just use tokens in roll 20. With tokens in Roll20 I can use a macro and API to causes a popup and message in roll20chat that includes a link to a handout on the item in question. Besides I would need to figure out how to export from CC3 with enough detail one could tell what the artifacts are. Example here zoomed in a bit in CC3. Obviously with some of these PNGs I would need to go back and figure out how to remove the backgrounds if I was going to insert them lie this directly on the map. There is a little more detail on the ground floor but I will share once it is closer to being complete again. One thing I am running into is this is a map for 1920 North America and finding symbols for things like Lamps, Coat racks, phones, and decent couches/sofas is near impossible..well that exist with the content I own which is all annuals CD#, CC3, DD3, and two of the symbol sets one being modern if I recall. I did import a few symbols I already had but most were 3D for something I was working on and do not look right. if anyone is aware of a source of 1920 or even more modern symbols I might be able to leverage I am all ears.
1920s Town
Once I create some things that look halfway good I will post them. And honestly what is important is do the maps in things help your players visualize what your trying to imagine. How historically accurate I think is secondary. :-) I did create this overland journey map but it needs a lot of work to be good.
However, it still will work as a visual prop in the game.
I need to find something better to use for the trail and take my time moving the panes etc so they line up. + The map could use a few text labels as what you see in the background is a bitmap of 1920 world map. Due to size etc I am starting to think what I need to do is connect the circular graphic to the trail via a different line and put the text label there it make more room.
Expanding Endless Sea of Ice FR
Forgotten Realms Interactive Atlas repairs.
