Cannot figure out how I broke the sheet effects - they won't show up
 GreyhSeer
                Newcomer
GreyhSeer
                Newcomer
            Hey everyone. I've been playing with CC3+ as a new user and I've run into a problem. Somewhere along the line I've made it so my effects are not working. I've checked my Merge Layer and I've checked that my text is on the right sheet....but I still can't figure it out. I've been searching the forums and google for 2+ hours and I can't figure it out. I'm super frustrated.
Any help anyone could provide would be super appreciated.
Thank you!
Your effects aren't broken. They are just scaled really tiny - so tiny you can't even see them.
I've just been through the whole set and discovered that you have them all set to Percent of Drawing Extents Width as the Effect Units. This means that whatever figure you had in the Edge Width box (these were also really tiny before I started on the map) is only that percentage of the map width.
I've changed them all to Map Units and given them about 10 map units Edge Fade Inner. I've also moved that piece of scrubland fill to the TERRAIN DESERT sheet because it was on the same sheet as the grassland behind it. That was why it wouldn't edge fade.
You will probably still need to adjust them all to suit your taste, but at least you are on the right track now.
To edit a sheet effect you need to pick the sheet in the list on the left and then pick the effect you want to edit and click the Edit button on the right.
Awesome! Thank you so much! I'll play with these settings and see if I can get it figured out. Thanks again!
You're welcome :)
