Switching between Cosmographer and Dungeons
HelenAA
🖼️ 19 images Mapmaker
OK, I was working on a Cosmographer file and decided to do a room in Dungeons.
I went through the wizard, Deciding settings. Then it got weird because instead of Dungeons fills I still had the fills from Cosmo. Everything else was OK - it was just the fills that were hugely different.
I went through the process twice more before I finally got the fills. Anyone else had this?
The question is...
- Which of the Cartographer's Annuals do you think these images came from?5 votes
- 201420.00%
- 201660.00%
- 201820.00%
I've just remembered that one fill is on the list of fills you get when you click "Advanced" on the [DRAWTOOLSP] pane but I can't find it to use the flipping thing - it's 'English Daisies" - although there's one more word and as I'm on my Mac and have limited time just now, I can't check.
I've made a dungeon from scratch and the fills are there (where I got the daisies from I don't know, by the way) but I've lost the snap without right-clicking on [Grid] in the file once saving has been done.
I'm gradually losing the Snap function from the creating-the-file process, first Cosm, now Dungeons ... Why?????
The only way to get Snap to work is to make the map then right-click to activate Snap!!
It is also dependent on the template if cursor snap is on or off. With cursor snap off, you won't see the actual snapping until you click to place something, and then it snaps into place, but with cursor snap on, the snapping happens alrady with the preview at the cursor.
Since not all templates comes with the same settings by default here, and the settings changes with each map you load/start, it may feel like it is behaving erratic.
