Sorry if this isn't correct place
HelenAA
                🖼️ 19 images Mapmaker
                                  in Site Matters
                    I can't upload a .png dimensions 1024 x 768 in the Show and Tell.
I'm starting a new discussion so I don't know why it says it can't find the discussion!
Here's the error message
Some problems were encountered
The requested discussion could not be found.
Or, you can just change the size in the options dialog in CC3+ when exporting. You find that by clicking the options dialog in the Save as dialog in CC3+, AFTER you have picked an image file type in the save as type dropdown. In the dropdown, you can also select JPEG instead of PNG directly.
.png files usually work out fine in the forums, but they are larger than their .jpg counterparts, leading them to be over the allowed files size in some instances. This is why you may run into problems with them here even if you normally don't.
I then look at the file size, if its over 1 megabyte, I use Irfanview to again reduce it.
In windows the easiest way is using win+shift+s to use the snipping tool and then paste into an empty jpg in paint. The files are almost never to big then.
