is Vintyri Still Active?
Got this stuff downloaded and installed and it all looks fantastic, However, the CSUAC/DA Map and Dungeon Dressing files are not showing up.
They are the ONLY ones not showing up and i was looking to ask for some help... but it seems that when i try to go to the Vintryi website it's not connecting...
Can someone point me in a helpful direction?
How is it not showing up? Don't you have the correct menu options, or do the symbols show up as red X'es?
, there was a notice just below the first paragraph that the download links had moved. And provided a different page for the files.
On my cell phone.
And to answer your question Monsen, I have all the menu stuff correct but i get red X's, and i installed all the Vintry stuff in the same data folder, like the instructions said. The DA Map and Dungeon Dressing is the ONLY one that gives me red X's
The files from the Dungeon Dressing Category should be from the dj_vol2_part3.zip file. This zip file contains all the dungeon dressing stuff, plus some additional files for the furniture category.
You can easily check if this is correctly unzipped by checking inside your @Symbols\Dundjinni Archives\BL12_Dressing folder. If everything is correct, you should have a bunch of folders in here, first one being "Battlemap Tiles" and each of those folders should contain a bunch of .png files. Any additional or missing folder levels besides what I have described means that something wasn't unzipped, or unzipped to the wrong location.
Are the Vintyri symbols meant to be multi colored? I'm seeing a few that have different roof colors...
( Such as Building 23 in the Base & General Buildings sections, though i assume this is to represent a stable or something of the like attached to the house, and their for a separation of the two structures. Or like Building 25 in the General Buildings sections which looks like it's checkered with the same style of roofing but with a lighter color)
... If so, cool, i'm just curious and wondering now sense it seems like i might have done something wrong in installation above and that might be affecting other things.
heres what i'm talking about, for clarity.
Alrighty, im going to try and re-install the Dj Vol 2 stuff and see what changes.
Thank you for your help, i'll report back soon.
Thank you again for your help Monsen! and it does appear the buildings are like the above because of the architectural design of the buildings in real life. So that' neat!
https://www.vintyri.org/vintyri/cc3p_addons.htm
