Smooth path lines showing
Hello, all. Brand new user. I was following along with the tutorial and things were going great. And then, I must have changed some setting because now I see the sharp angled lines that define the smooth path that a road or river follows. I'm probably not using the proper terminology because I can't find a solution online. Help?
CTRL F turns the frames for smooth paths on and off.
Frames are useful when you need to edit the path using the delete or move node tool.
