recover old autosaves?
                    So I spent some 30-40 hours building my first 'real' map after I got ahold of how things worked and many of the odd little nuances that comes with this program.
And apparently it never saved.
It saved as an autosave. But it never saved an actual file.
Well. Needless to say, I went to find it and open/edit a thing or two along with process a few completed jpegs.
Aaaaannnddddddd it doesn't exist.
I looked everywhere. And by everywhere, I mean EVERYWHERE. And nothing. The last few weeks I thought I was going insane. Remembering things that never happened.
But low and behold, I has 'pring screened' and sent a screen cap of a partial to a friend on discord. Proving that I wasn't crazy.
And I found out it was saved as an autosave.
Unfortunately I created a new map a few weeks ago for a campaign I was running and it autosaved over the big map that I need.
Is there anyway to salvage an older autosave? Or something like that?
I figure I'm just up the creek without a paddle. But man would it be nice if there was some way to fix this problem. Preferably without me kissing all of my work.
And as for why this happened?
I thought that when it autosaved, it overwrote the old file. Like, well, everything else I've ever worked with. I didn't know that it didn't overwrite the original file. It just made an autosave and overwrote that one.
The only way to get something back is to open that autosave file the moment you next open the app, or you will lose it under the very next autosave.
I'm a bit confused when you say you lost 30-40 hours work. Surely you have only lost the most recent day's work? It would be truly unfortunate if you had been mapping non-stop for 2-3 days without sleep and never manually saved the map in all that time whatsoever.
That's the main reason why I never bothered with anything else. I had started a save file when I first started the map. I thought it was saving over that file. And I never opened anything because it was always conviently present when I was working on it.
I am so sorry to have to tell you this, but I can't leave you hanging without an answer.
That button only confirms that you agree to an autosave. It doesn't do an ordinary save. You have to do that by clicking the disc icon, hitting CTRL+S, or using Save from the file menu. I think CC3 also asks you if you want to save changes when you shut the app down.
I can't bring your map back for you, but if it is any comfort this thread has sparked a tech discussion on the way autosave and save work in CC3.
1) Start a map.
2) do some small amount of work on it.
3) save as nameofmap01_001
4) do some small amount of work on it.
5) save as nameofmap01_002
continue on until completed.
I use this method in case of a computer crash, which mine does. And if I decide to go in another mapping direction, I can go back further than undo.
I would have done something like this had I known that's how it worked.
I probably just overlooked the details when I skimmed the instructions or something. It's my fault. And that's something I'll have to live with as I remake this thing.
And with that, a moment of silence for the only living screen cap of a portion of my map.
For future reference, if you have to open the autosave make sure you save it immediately over the original file and leave the autosave to be what it is.
But the good news is that you can import that image into your new map and use it as a reference
Let us hope it will be that way for you
Autosave saved me an hour or two today.
What baffles me is I set up my autosave feature today, just because I am doing longer and longer sessions. (plus crashing issues)
I did an autosave then I exited out of the program. I went to my file and it was an hour or two behind.
So I have to make sure to do a full save each time I exit the program? Hopefully CC4 will autosave the current drawing to its destination if that is the case.
I really like the progressive save file numbering hint that Jim gave. I do that when playing games like skyrim. I had over 200 saves for that game. So maybe I will take to doing that with my CC3+ maps.
Autosave deliberately save to a separate file to make sure to not accidentally overwrite your actual map file with what is perhaps unwanted changes, for example when testing things.. This is how autosave works in most software. I guess a more correct name would be "recovery save" or something like that, but autosave has just stuck in most software as the common term. It is not a replacement for manual saves, just an extra layer of security, so yes, you should always manually save before exiting. (Personally, I have autosave on, but the dialog off, so it autosaves silently in the background, which is what most other software does by default)
