Change of user name
Hi everyone, I have changed my username from qwalker to my real first name, Quenten. Hopefully a picture will also appear. If it doesn't, can you let me know how to do this. I have reduced the size to 210x200 pixels, and put it on my facebook, with the link from there. It doesn't seem to appear.
This is the picture.
1. Unfortunately, the profile doesn't support https links, they need to be http.
2. Secondly, that link of yours is to a page on facebook holding the image, not a direct link to the image itself. The link must be directly to the actual image. (I am not sure if Facebook even allows embedding of images hosted at their platform?)
I think you should be able to link to the image attached in your post above though (URL is http://forum.profantasy.com/extensions/InlineImages/image.php?AttachmentID=7431, just make sure to never delete that attachment if you do)
Er, no it isn't
Let's see if this does it. The bigger pic did get loaded onto my account page, though.
If you want a small image in your post, like my dragon, you need to provide a picture url under the 'icon' setting. That should be a 32x32 pixel image, and you should be able to do the same trick by uploding it here, and use the url of the attachment.
Edit: I see you got that fixed now.
Do note that the small image can be difficult to interpret unless you have already seen the larger one. Since they are two independent images, you could crop the icon one closer to your head if you wish. Just a suggestion though, it is up to you what you prefer.
You are not how I imagined you at all, Quenten!
Isn't it strange the mental images we draw of each other, based on an avatar name
Oh yes - and don't worry, you look a lot better than I thought
The second picture is better - we can see you now
It's good changing up the appearance every now and then. But I think I'll stick with my own beard for a while yet, haven't had it that many years.
