HelenAA
🖼️ 19 images Mapmaker
I cant get the frame to show properly when I have exported the map to .png so I can see it on my desktop. It is there in all its (boring) glory in native format but not after export. I'm uploading the .fcw file but can supply the .png if its wanted
CG
You can also do a Save As, and select Rectangular PNG from that menu. Using the mouse to make a square/rectangle at the outer edge of the frame. Upper left to lower right.
