Is there a quick way to find the angle between two lines?
I can get the bearings of both lines and subtract one from the other, but just wondering if there is a way to do it in one step. If there isn't, it's probably a job for a macro, right?
Thanks in advance.
    There isn't a command for that as I am aware of. I guess you could make a macro for it. It gets slightly complicated because there isn't a command that takes the bearing of an entity and store it in a variable, so you'll need to do some tricks. Haven't tried it myself, but it is probably doable.
  • Thanks. Are feature requests a thing? Angles are not a huge priority, but something I would find nice to have, along with dimension line adding tools.
