using Random Street option
HelenAA
🖼️ 19 images Mapmaker
I've been trying to make a walled city from scratch and I've hit a brick wall in terms of the random street.
Making the walls was time consuming and many versions fell in the process, but eventually I succeeded. Then, I put houses in, using the Random Street tool(?). At that point I didn't realise I had to put roads in first if the houses were not to be in straight lines so houses went in first accepting the default colouring which I quite liked. Then the roads snaked their way between houses.
Then I exported the map to a pdf file. The roofing was a green-red-brown in colour - not the grey in Cities! Not to my taste at all, and definitely not the colour for my large part continent map I've got in my head.
My questions are
1. how do I change the colour so I get a colour I like and am expecting on export.
2. I've tried to resize the houses but I can't get it to work so I can shrink the walls and just put new houses in as the existing canvas size is massive.
The map is [b]not[/b] for gaming but for a story I'm working on.
I'm uploading a cropped pdf which has the only got the city so people can see the exported file. If anyone wants the FCW version I'll post it tomorrow.
Thanks for any input.
PS the roads are 3' Paved yet they suffer the same colour change!
Helen
My questions are
Helen
Do you have any effects that may change the color. Try to zoom real close into one of the problematic houses, and then toggle the effects to see if there is any difference
What seems to be the problem resizing houses? Houses drawn by the random street tool should scale normally when using the Scale
I zoomed right in on one roof from the Default setting and the roof did separate into the speckled effect just in the file I included above. It didn't have anything to do with effects; I don't know how to do anything apart from shadows.
I don't know how to use the Scale command, I get as far as selecting an object and Right clicking to get to the " Do it " list. What is meant by scale origin for instance? I've always selected a house, for example, and then hit Enter and changed things thag way - that's why I'm struggling, that and having poor precision and spacial awareness.
I'm attaching a trial FCW file so you can see what's going on. Oh, the roads are using a fill from Floorplans* -> Streets -> cobbles and the same thing is happening as the roof symbol from above.
*Set B I think
I am still a bit unsure about this color change. I don't really see any color differences when I export the map. Could you provide two screenshots with a side-by-side comparison of what you see on the screen compared to what you get in the pdf? Might be best to do a zoomed in view that only contains a couple of houses so it becomes more apparent, it is difficult to pick out anything from that overview screenshot above.
I'll try but I'm typing this on my Mac and my PC laptop is where I make my maps, (obviously). It won't be for a few hours (from posting) as Monday mornings are when I have some weekly commitments.
Thanks for your help with this and your explanation of what scale is.
There isn't the same number of pixels available when looking at the house when zoomed out compared to zoomed in, so some details in the pattern may not look the same when zoomed out since all the detailed cannot be represented in the smaller amount of pixels, so some of the pattern a speckles may vary a bit due to this, but as far as I can see, the coloration is the same.
