SOLVED -Removing the outline from a drawing tool
In the attached image there is a section created with the Default Terrain Drawing tool (style = Dungeon DD3 Color) which has a black outline around it.
How do I remove change the drawing tool so it does not create the black outline?
Thanks.
Jason
Thanks.
Jason
Note that you should create a copy of the tool rather than modify the original. To do this, just make the changes, but hit the 'New' button instead of the 'Save' button, as this will create a new tool using the current settings. You'll need to change the name obviously, the suggested name is the name of the existing tool, and will overwrite it if used.
After I made the changes to the new tool (and saved it) I still got the same results.
Jason
Jason
You can also do a list on the entity and the line.
type list and then click on the edge to be both. The command area in CC3+ should say 2 selected.
right click do it.
There are tag numbers for each item. They will be different.
Click on Erase, right click above the map. A list shows up. Select More, then Entity Tag #.
Type in the tag number for the outline.
Press enter, outline gone.
Note that these tag numbers change from map to map.
Jason
Thanks to everyone that replied.
Jason
