[Bug?] Copy to Clipboard not working right after Patch 8
I believe this was mentioned somewhere before regarding copying text between maps, but I'm having the same problem using Copy to Clipboard with non text. If I select a few entities in a map using Copy to Clipboard, the entire map is copied to the clipboard when I try to paste it into another map, not just the entities I selected.
Anyone know what's going on, or if there is a workaround?
Edit: actually it wasn't the entire contents of the map getting copied with Copy to Clipboard, but far more entities than I actually selected are copied.
If it is still happening reliably with that map, please send it to me, so that I can take a look at it. Are you copying over to a second instance of CC3? Or are you opening a new map to paste in the same CC3 instance?
The source map was based on the old school annual. I hid the Grid and Background sheets before I did the Copy to Clipboard to select the entities I wanted to copy. I didn't save the source map either after I completed the command and opened up the new map to paste into. The extra entities show up every time I do it that way.
I made a copy of the source map with a different name that I saved with the two sheets hidden after I did the Copy to Clipboard selection. I opened a new map and went to paste, and the first time I got the extra entities I didn't want. If I reopened the copy of the source map and tried again, the second time only the entities I wanted to select got copied over to a new map. Again, all of this was within the same instance of CC3.
Ralf, I emailed you copies of the FCWs - thanks again for your help.
http://forum.profantasy.com/comments.php?DiscussionID=914&page=1#Item_29
Is there a way to revert to patch 7 until this is figured?
What I do is make first try, undo, select again, copy, fine.
But having entities placed on the correct Sheet now as well as Layer with Copy to Clipboard is far more valuable to me.
Joachim's workaround of copy, undo, copy seems to do the trick for me. Yay!
I agree jaerdaph that this update has many little improvements that are more than just a little valuable. But I'm in the process of reviving my original AD&D 1E campaign (family and old friends have recently move back to the home town). All of my maps are rumpled, faded, stained, and hand drawn. I've been experimenting with different styles to see which I liked best for this campaign. I mapped my world out in basic vector shapes, but wanted to copy one of the land masses into the different templates to play around with. The glitches in the copy to clipboard had me pulling my hair out.
All is well now. I should have known to just ask here because someone would have a work around.
When I 'save as' bmp, and use Irfanview to convert the bmp to a png file. That works everytime.
