Edge Striping example map - The Allaluna-Meloa Isles
Hi Everyone
This is an example map I made to illustrate an upcoming PF blog. It's the first time I've used the Edge Striping sheet effect, so many thanks to Remy Monsen for helping me understand how it works!
[Image_14376]
[Image_14376]
It's pretty much a straightforward Mike Schley overland map with a bit of effect tweaking and the edge striping added.
It's all in the blog - as well as two additional new edge strip images to use.
The images are located in the @Profantasy\CC3 Plus\Filters\Images folder. How many you have there depends on how many of the annuals you own - which is why with Remy's permission I provided the one he made and the one I adapted from it.
The FCW for this map will be provided as a link from the blog, so you will be able to see how it was done first hand.
I want one which is thicker on the inside, and thinner on the outside, and another with varying shades of blue.
