maximize resources
What settings, (if any,) can I change to maximize the resources available for CC3+ ver 3.91, and where do I find these settings? I have a pretty bad habit of wanting to make maps that are larger than life, and though I'm certain the computer I'm using has the resources, the program tends to lag & freeze.
Thank you.
I
Thank you.
I
Update, as Merion suggested.
CC3 is currently a 32-bit app, so computer power will only get you so far at the moment. You can alleviate some of the lag in a map that is unavoidably large and heavy on processing by placing collections of things on separate layers. That's layers, NOT sheets. For example, if you are making a city map you might have all your buildings on the same sheet, but different districts on different layers. That way you can hide all the districts you don't need to be able to see while you are working on a new one, and the performance will bounce back to normal because CC3 isn't having to constantly redraw all that other stuff.
Here is the city. P is poor, M is military, etc.
I made an absolutely enormous jpg render of the background floor texture only. (there's no kill like overkill) and now I can just put that in as a background.
I
This map requires DD3, SS1 and SS2 installed for it to work properly.
I
(SS5 is newer than annual vol 10, but everything else is older.)
They should have been. I must have been tired when I was installing this. It's very strange.
I installed them (again?) the keys self populated....
At any rate, it is working now.
Thank you!
