Setting up and using perspective in overland maps.
You can probably tell I'm working my way through the Tome of Ultimate Mapping. I've hit another problem with one of the tutorials about using perspective in overland maps (p.178).
I've followed the tutorial to the letter using PSCALESETUP. But when I execute the PSCALEX command the shape of the map does not change to perspective view and when placing symbols after executing the PSCALEON command, the symbols do not scale when moved around the map on the cursor and placed.
Can anyone help a newbie?
Also, when running PSCALEX, the program should ask for a selection. You did select the background and then then 'Do It' during this, right?
Generally, make sure to keep a good eye on the command line and do what it asks.
If you are making a 1x1 map as in the tutorial, also make sure that SNAP is turned off, otherwise you'll struggle getting those points placed at all, because default snap positions for overland maps are much larger than the size of this small map.
You did change the scale of the symbols before you started, right? On a 2x2 map, the default symbol scale is 0.002, which is so small that it is difficult to observe the effect. 0.02 is probably more appropriate.
Try doing that and see if it works then.
