Posted By: QuentenDalton, the http address I use is: http://fantasycities.watabou.ru/?size=199&seed=123456&name=Whatever you like&hub=1&random=0&citadel=1&plaza=1&temple=1&walls=1&shantytown=1&river=1&coast=1&gates=5 0=off, 1=on <---- snip ----> &gates - specify number of gates - this needs to be added each time if you want specific number, otherwise it is random
Does the number of gates determine the number of roads generated? Also are there fields for switching “Farm Fields” or “Elevation” (or any other) options on and off? I’m thinking of the “Options -> Layout” menu but any fields to set the “Options -> Style” menu options would be welcome too.
It doesn't really look that gate number affects roads to any great extent. The only options are what is there as far as the http is concerned - the rest you do in the generator itself. methinks I will have to write a user friendly tutorial on Watabou generator.
It seems to me that there must be at least one road for every gate into the city. Can a city have &gates without &walls? Also a “user friendly tutorial on Watabou generator” would be a very good idea! 8D (It would be nice if the Watabou algorithms could be licensed to Profantasy to upgrade the random CITY command. )
&gates
without&walls
? Also a “user friendly tutorial on Watabou generator” would be a very good idea! 8D (It would be nice if the Watabou algorithms could be licensed to Profantasy to upgrade the randomCITY
command.
