Output scale problem - pixels per grid element
This is something that I have allowed to frustrate me to epic levels - probably should have asked here sooner.
I have a map. When I go to the the RESIZE DRAWING AREA dialog, it is 430x310.
This should mean that if I want to output the map at 200 pixels per 10' grid item, I need to set the export feature to output at 8600 x 6200 pixels. Yet when I do this, I end up needing to scale the grid to about 190 pixels per square before it fits correctly.
I can only image that the border is going out there at some unknown width. How do I get consistent scaling regardless - or in spite of - having a border? When I say that using a 200px grid will work, I want it to actually work.
Thanks in advance
Top
Thanks in advance
Top
Personally, I always use the 'Rectangular png' export option when exporting battlemaps and other pixel-sensitive things, and always specify just the map, not including the border and screen. The other option is to make sure your border is exactly a whole grid square in size (and include this extra square in your calculation), as well as making the same considerations for the screen if it is present.
As for the 'Resize Drawing Area', this reports on exactly that, the drawing area, not additional stuff outside it (like border and screen), so it is not suitable for export calculations for whole map exports, to get accurate measurements, use the distance tool instead.
https://i.imgur.com/5yzKDTc.png
In the linked image, you can see the numbers for the grid coming through (in small part) on the left. There is very thin white border on the right as well - nothing on the bottom or top. The border is completely turned off.
Top
Top
Still, as long as you use the rectangular export setting when exporting, you'll get exactly the part of the map that you want, avoiding that white border.
(Also, make sure that your export options is set to crop image to aspect ratio AND that your calculated width/height is 100% correct)
That white ribbon is usually the result of one of two things:
- Either, there is a screen there (usually a white polygon, so it is normally invisible during the normal editing process, but it is still there, and turns up on drawings)
- Or the crop to aspect ratio export option is not set, so CC3+ enlarges the area slightly to make the export the exact same size you specified in the export options.
Top
Top
Here is a related wish-list sort of thing.
I would like to reveal or show only a small portion of the gridlines. This would allow the end user to coordinate a software-base grid (i.e. Fantasygrounds) without having a grid over the entire map. Is anyone aware of good example of how to accomplish this? A circular, fading reveal would be nifty :)
Thanks!
Top
