Repair Install: Refresh my memory?
Okay... starting yesterday, I can't remember if it was before the Window's Update, or after, but something's going on with my laptop, and my CC3+. I can't seem to access my file explorer or campaign cartographer. Anything else on my computer I can do: get online, play whatever games I have installed... But every time I try to access my file explorer, it opens, then freezes on me, which means I can't access my external hard drive. Samething with Campaing Cartographer, which runs out of Program Data, but all of my fcws are in my external hard drive.
I did just have an update, and thinking that might be the problem, I went through 5 hours of a system restore, back to before the update... but that didn't fix the problem. I ran a diagnostic on my hard drive, and external hard drive, both seem to be working properly. The best way to describe the issue, is that my laptop recognizes the hard drive, and external hard drive, but can't seem to access them. Any program that requires files from either doesn't work as well.
I want to try to run a repair install on cc3+, just to make sure that it's not part of the problem, but I can't remember how to do that. Can someone refresh my memory?
However, based on the issues you describe with the file explorer, I highly doubt this will fix anything, just providing you with more work. My advice is to make your computer work properly first, then worry about CC3+. CC3 don't mess around with system files or the such, so I highly doubt it is what is causing your issues.
It could be that its nothing to do with either CC3 (which Remy has just confirmed) or Win 10.
Just for the record there have been an unusual number of driver updates... unless this is just because I have a new machine. Could it be, then, that a driver for the external drive has been updated when it should not have been, or has been updated in error I wonder?
But if I want to, say look at the pictures I have installed on my laptop, I can't, because when I open file explorer, it locks up. If I open CC3+, it locks up... but I think that's because there is an fcw WIP that cc3+ is trying to access when it opens. All of my map projects (WIP fcws) are stored on my external hard drive, which is accessed through file explorer. I can open up Microsoft Word, no problem. The minute I try to open up a WIP document, Word locks up. Anything that has to do with File Explorer, or has to access File Explorer, locks up whenever I try to use it.
And this just started, and I have absolutely no clue as to why.
But this is jumping to conclusions obviously, we don't know yet if that is even the culprit, but it is an obvious first step to try. Better find the cause first, then worry how to deal with it.
(trying to be positive here)
Well, I have some good news, and I have some bad news. The good news is the problem is NOT the laptop. It's the external hard drive. The bad news is... it's the external hard drive, which is where I put EVERYTHING that isn't an app for the laptop. All of my maps, All of my notes, my crochet patterns I'm working on... everything. Which means I've lost everything.... AGAIN...
It doesn't have to be irretrievably lost.
And it doesn't have to be the expensive end of the scale to get it all back again.
Have you tried plugging it into a different port, or using an alternative cable?
If you have, then it might be time to look into the customer ratings for a small range of local IT specialists who might be able to get most or all of it back again and put it on a new drive.
And I know saying this right now does not help you at all in this situation, but please everyone, ALWAYS keep a backup of your things. Drives break down all the time (or are stolen, lost or destroyed), always keep up-to-date (weekly minimum, daily preferred, I keep hourly) backups. And the backup should be on a different drive, preferably on a different physical location. These days, with the abundance of cloud services out there, this is easy to accomplish. Cloud services like OneDrive even keep file history (for a short while, but still) so you can retrieve an earlier copy if the latest is bad. Keeping an offsite copy also protects you against theft and fire as well. Even if you need to pay a bit to upgrade your cloud storage beyond the free tier, it is well worth it when it saves you from the grief of loosing a lot of important data. Personally, I just pay Microsoft for Office 365 which comes with 1 TB OneDrive storage extra for up to 5 accounts, which ended up costing me the same as just 1 TB of storage by itself from either Google or Dropbox. Of course, there are also actual backup services out there, they tend to be cheaper on the storage, but you cannot use it as a "daily drive" as you can with the aforementioned services.
And I haven't exactly lost everything... I may have lost all of my fcws, and works in progress... but I have jpeg backups here, at the guild, and I have a DeviantArt page, where I've been storing my jpeg maps. My poetry is backed up at allpoetry.com, and the two crochet patterns I've published are saved and downloadable on another crafting website. So I'm really just out of my cc3+ backups, my fcw's, and my game notes.
Hopefully Ben will be able to help me get it all back.
Sites like backblaze provide a very affordable service (flat fee for unlimited backup storage) and if you ever need to restore data from their service, you can either download it or have them mail you a drive with the data.
I have to start Ganocia, pretty much from scratch which means 4 months of pushing to get it done in time for summer... down the drain.
But it wasn't just my fcw's and jpegs that I lost. I had crochet pattern wip's I've lost too. The tutorial and the fcw's for my color wash technique, gone. Everything I've done in the past two years... gone. Actually, just about everything I've done since I got the hard drives, almost three years ago... gone...
book notes... pictures, backups... The Allenhold Commission that I was still working on, the new commission I was working on... everything is just gone...
I feel like giving up... all that work...
Good Luck !
I assume your tech is experienced enough to properly test out the "regular" stuff to try to get the drive working again (and failed). There are companies that specialize in the recovery of dead drives. They usually do a pretty god job with it, but it isn't cheap, but it might be worth it. For a hard drive, the data will still be on the physical platters, it doesn't just disappear, but usually it becomes unreadable because the drive heads failed or the drive circuitry dies. Bot of these things makes it impossible for a "regular" tech to do anything about it at all, but the proper data recovery companies have equipment to open up the drive and replace faulty parts. You may wish to talk to them and check prices.
This video (as well as this video) is both informative and entertaining (It is about it a youtuber visiting one of those facilities and getting hands on on swapping parts inside the HDD. It showcases what these guys actually do to fix drives. It is NOT a video with instructions for something you can do yourself.) [This is the company he visited, but there are others out there. Personally, I am not in the US, and don't have any real knowledge about any of the companies operating over there.]
as for all of those data storage sites. They are great... but they also cost money. Money I don't have to spend on data storage, which is why I haven't done it up to this point. The only free one I know of, is google drive, but I avoid google as much as I can. I use their email, (because I had to for a client), nothing more.
I guess all is not completely lost. Any jpeg I've saved to here, or the guild, I can get back. The Voud Califf fcw is part of the atlas, so I can get it back.
But there was so much on that hard drive, that I can't get back... and not just maps. Some of that data was profitable data...
And this is now the.... what....3rd time, 4th time... I've had to start over? Each of those other times... it was the program that failed. I lost my configuration, but I still had all of my projects.
This time I've lost years worth of work... and again, not just maps. I stored projects I've been working on for years on that hard drive... I just feel so defeated...
Both Microsoft (OneDrive) and DropBox have free options. Not unlimited space of course, but neither is Google drive, but you can still store quite a lot of important files on either of the services. Of the three, I prefer OneDrive myself. There are others out there too, but hose three are the best known ones.
I use a Synology NAS with two 4TB mirrored harddrives.
If one drive gives up, i just buy a new one and swap without loosing any data.
Its better and more reliable than an external drive.
But if you go that way its important to buy harddrives that are made for NAS as it runs 24/7.
That's the way I'm thinking of going - to have a second back up drive for the one I already have built into in my PC.
I'm going to see what the cost of data recovery is... see if there is any way we can afford to do it. But that will probably be a month or so, at the least. I don't know...
I'm not saying that everyone should do it, and if you are happy with the owned version anyway that's fine, but when I was considering whether I would buy the newest copy of MS Office or rent the 365 version I decided the cost of owning it and updating each year to keep it in date on a par with the 365 version was about the same as if I just rent 365. The thing that swung it for me was the Terabyte OneDrive that comes with 365 for no extra cost.
I haven't started renting it yet (it will be several weeks before I can afford even that small outlay), but I will - and all my graphics can then be backed up on OneDrive.
https://www.easeus.com/datarecoverywizard/free-data-recovery-software.htm
I got almost all my photos back.
Try use the free data recovery to see if you can see and recover any files that you have.
If it works then $69.95 is a cheap price to get all the files back.
