Making City Maps
                    Ok, when any of you make a city map (large city to metropolis size) what size template do you use or recommend?
Anna M Dobritt
Cartography Unlimited for RPGs
                            Anna M Dobritt
I draw the roads, etc. so they match along the edges.
One example is here:
part 1 of the city Tooshla, Gashtra
part 2 of the city Tooshla
One method I use to get the edges to live up is here:
JimP.
this was for a city of around 50,000. Also the bigger the city the less detail/shading you should put on things like the buildings unless you want a really large file size. I can see this becomming even more so assuming CD3 makes extensive use of png symbols.
If you rummage around the site you will find some other cities and villages too.
Futuristic towns may be even bigger in area if they have such facilities as starports etc. While medieval and ancient towns would generally be more compact for a given population and thus could use smaller templates. One way to achieve this is to assume that average population per house in the medieval and ancient periods is between 6 and 8 and for modern and future less than 6. (Our house sitting on 9.8 acres currently has 3 residents).
This will make a big difference to the template you use. Taking my city of Pathen as an example this is a late iron age city of approximately 50,000. This was done on a custom template of 6000 x 4800 feet so the template is just over a mile across. The same city designed for the modern era may be two to three times larger, partly due to less crowded housing and partly because more facilities may be present, you know things like an airstrip on the outskirts, railway station, petrol/gas stations etc. You need to keep in mind what your settlement is going to be like and then select or create a template for it.
I tend to work in two ways.. some times I'll just map the entire city on one main map, other times I'll go and map it on one then split it into several smaller maps.
In part it depends on what your doing etc. I find that the templates are normally way to small for me most of the time, I posted two maps I upload a while ago to the mailing list a while back, and I've got a few others I need to upload and the like to show, I'll try and get around to putting them up soon.
The end result though is that it comes down to what you want and how long you want refresh's to take. Even the vector stuff takes a while to draw (Heck actually I find it tends to take longer then the bitmap stuff after a while) which is in part why i keep hoping that CD 3 will hurry up and come out hehe.
-Rob
Heh. Thought about making the population 100,000 but that seemed too much for me to work with.
Anna M Dobritt
Tallknight
Anna M Dobritt
