HELP - Odd error after installing
I've been forced to install the CC3 again, and I'm getting this error (it's translated from Spanish to English, so it may not be accurate):
Entry point to process _XPRegisterHelpSvc@4 can't be found in the library of dynamic links fcw32.exe
And then it says:
Error 00000007F loading XP module: xphelp.dll
But otherwise the program seem to work fine. Until I install the newest patch.
The patch gets installed but when I check the version it says it'¡s version 3.02
Can anyone help me?
Thanks in advance!
And then it says:
Can anyone help me?
Thanks in advance!
I haven't seen this exact problem, but if you are using Windows Vista, you should try follow the Vista install guidlelines
Other than that, you might wish to try to contact ProFantasy support directly
I've contacted ProFantasy Support, lest see what they tell me.
Thanks for the help Monsen!
