Argh! CC3+ crashing after upgrade
I just ran the Update18.exe for CC3+ and since then anytime I try and press the "Add Room" button CC3+ crashes. I've re-run the Update twice.
Any ideas on what to try next to fix this?
Thanks
Blakey
Thanks
Blakey
I don't suppose this is anything to do with different kinds of AV interfering with the process of installation, is it?
I always install as Administrator, but I usually don't bother turning off my AV these days. Its just unnecessary hassle when Win 10 Defender doesn't seem to cause any problems with PF installers, but maybe with all the recent changes in firewalls and such this is actually becoming more of a problem?
Just guessing...
Ralf, both file dates are from October 19.
Thanks
Blakey
Asking because that seemed to solve the problem for Shessar, Blakey and also someone else over at the Guild - that's all of the three people who have mentioned this on either forum.
Yes I have tried several reboots, I have fixed the selection issue but still having the problem withthe auto cut.
Regards
Kieron Williams
Blakey
1. Create a map using City Designer.
2. Press the 'Dungeon Menu' button - this flicks all the left hand buttons into 'Dungeon Designer' mode
3. Press the 'Add Room' button.
This consistently crashes for me and is a right pain.
I think I can solve my Battlemap woes by being able to start the map off as a City Designer map and then flip into Dungeon Designer for things like buildings. Should this be possible?
Thanks
Blakey
Win 7 pro with all products loaded, and beta update 18.
it is not very pleasant when you want to create a dungeon and each time disappear parts of the walls when you set a door
As a workaround, you can remove this file
OPENDOC @on the command line and hit enter)I just did what you said. Mine still crashes. It's even worse now as I can cause it to fail like this:
1. Open CC3+
2. New Dungeon.
3. Default settings
4. Click "Add Room"
5. Crashes.
Utterly repeatable.
Very annoyed as I have a night off and 6 hours to build maps (which is HUGELY rare for me) and the software is broken. :(
Next effort is to uninstall and reinstall everything...
Blakey
I will just be waiting for the fix, but then I'm not trying to map a dungeon tonight.
Will let you know if it works in a short while.
Blakey
You should be fine as long as you remember to follow the installation instructions, switch off AV and install as Administrator.
So I have just switched off AV and am installing as Admin. Let's hope this makes everything rosey!
Worst thing is that I can still recreate the crash. :( Now I am really stuck.
Blakey
- CC3+ first, then 17a (in your case)
- All add-ons, symbol sets etc
- re-run 17a
Attempt number 3!
(THANKS HEAPS FOR THE ONGOING HELP!!)
