Cannot uninstall nor reinstall or update
Hi There,
due to limited capacity on my c drive (win 10 computer) I decided to install CC3+ to D:\ drive. However, none of the addons works as it always says "cannot locate CC3+, please install first"
Okay, I thought to myself, why not uninstall CC3+ from D and reinstall to C (and install all the addons to D)?
But although I correctly choose the folder with the local setup file for CC3+, which the uninstall routine asks for, the unistall execution always breaks and does not execute.
Now I can neither uninstall (and reinstall) CC3+ nor any of the addons.
Please help
Please help
Have you tried just running the installer instead of using the uninstall? The installer should detect that CC3+ is installed, and offer to repair or uninstall it. Or, if it doesn't, just use it to complete the install in the new location and then manually remove the old files from c:\ (Only things that need to be removed is c:\ProgramData\ProFantasy\CC3Plus, the data directory. The program itself will always be installed to the C drive [but this is only about 50MB anyway], the option the installer gives you is where to put the data directory [which is what takes space])
If this doesn't work, I recommend you contact ProFantasy technical support, they usually have quite fast response times.
- install as usual and instead of using c:\program data\ProFantasy\CC3Plus during the installation routine I should choose another with more space?
Is that correct?
Thank you again for your help.
