Removing a node
RobertR
Newcomer
I have a couple of spurs on my map that I have tried to find the node to either trim or delete. Is there a way to show the nodes or is it just a click until you find?
Note that those spurs you see are caused by nodes being to close together, combined with a sharp angle, so the offending node in that case will be along the coastline, and not at the end of the spur. Probably located somewhere in that bay which seems partially obscured. These problems are more common when the line gets very wide compared to the angle of the corner.
Yes please!
Mind you - it would do away with the many happy hours I've spent deleting badly behaved nodes
