'No draw tool matches your current draw tool'
HelenAA
🖼️ 19 images Mapmaker
i'm having problems and keep getting the above error message (I've abbreviated it slightly but the overall message is there).
Somehow I found myself in the CC3+ Overland menus and I can't get myself back to Modern Floorplans! Everything I've tried has failed; closing and opening, clicking the SS3 icon, in short, checking everything I can think of. I know I'm coming across as being thick, but I have run out of ideas, but I need things like Modern walls and carpet (stuff from the Drawing Tools that I can't get at in other ways).
Please help!
Please help!
As an aside, what's the best way of putting shading as though down a shaft? That was what I was struggling to do when I lost the SS3 Drawing Tools.
Many thanks for the quick reply.
Just one of them is to alternate sheets of solid transparent black with sheets of the things you are going to line your shaft with, and make the shaft progressively smaller into the background. This example is based on a technique I've seen Lorelei use, but to be fair I think I saw it before that. I just can't find the thread. Herwin Wielink mountains used as jagged teeth down a shaft.
There's several different ways you can approach this, such as these two options:
I hope that helps — or at least generates some ideas.
Cheers,
~Dogtag
how do I make deep cave in CC3/DD3 ?
Then all you have to do is use Export (usually also under the File menu) and save it as a jpg and upload it
