Fill Style Dropdown not wide enough
In DD3, I'm using the 'Add Room' command. When I try to select any of the Fill style's (Floor - background, Floor - foreground or Wall) the dropdown box is not wide enough to be able to see the full name of each of the styles.
If, for example, I want to choose a Wood Floor Style all I see is the words 'Wood Floo' which is not enough information for me to pick the specific item I want. See attachment for full details.
Is there a work around for this?
Daniel
Daniel
The order of the items should be in the same order as the main fill style dialog though, so although cumbersome, you can get some information that way, and also through the preview.
The suggestions you both supplied are very helpful, I will give them a try.
