Quick Tip 001 - Open CC3+ data directory in Windows File Explorer
Monsen
Administrator 🖼️ 82 images Cartographer
There are multiple ways to find your CC3+ data directory using Windows File Explorer. But the easiest way is to just tell CC3+ to open it for us. This works no matter if you installed it to the default location or not, and if you have enabled viewing of hidden files or not.
Inside CC3+, simply type the following on the command line (followed by enter):
The opendoc command is used to open files from CC3+ (great for use in hyperlinks) and the @ is a reference to the cc3+ data directory.
Just note that this is a way of opening a new Windows File Explorer window on that directory, it cannot be used as a quick navigation in dialogs, such as the open or save as ones.
OPENDOC @The opendoc command is used to open files from CC3+ (great for use in hyperlinks) and the @ is a reference to the cc3+ data directory.
Thanks Remy
