CC3+ unusable in Virtual Machine on my late-2015 iMac
Hi everyone! Hoping for some help here. I'm trying to run my CC programs via Virtual Machine on my iMac, and as the title says, it is unusable. Any given map can take 5 minutes or more just to load, to say nothing of how long it takes to apply any changes I might make or reload a screen. I'm running Windows 10 in VM, then CC3+, and have nothing else running on my iMac at the same time. This computer is so powerful compared to the specs for CC3, I am baffled why this is happening.
CC3/CC3Plus are 32-bit programs. They will use 2 gigs of ram, but if you have a 64-bit computer it will use more, but less than 4 gigs. Video card isn't used.
I don't have a Mac, but you might search the forums and see if another Mac user has made a post similar to yours.
My iMac has 8G of Ram. I use it for video editing with no problems, which is hugely Ram intensive.
This is so problematic, I am considering spending $200 on a Lenovoa Ideapad just for a cheap PC JUST for CC3+ etc, but I'm unsure that the limitations of a bare minimum laptop like that will run it smoothly. 2gigs of Ram is the best the cheap ones come with, for instance.
Did you install the corresponding VM Additions in the Windows VM?
What are the specs of your Mac?
What are the specs of the VM?
Are you running any disk encryption software? Antivirus? Other intensive CPU/Disk usage software that may be running in the background (either in Mac or Windows)?
iMac specs:
3.2 Ghz Intel i5
8 Gigs Ram 1867 Mhz DDR3
AMD Radeon R9 M390 2 gigs
VMWare Fusion Windows 10 x64
No, I am not running any disc encryption software or antivirus. I even tried turning off my automatic backups. Nothing is running in the background that I am aware of.
EDIT: Never mind, I didn't see it listed at the end of your specs. I see it's a Win 64 emulator.
What I meant by additions, is the "drivers" that you must install in the Windwos VM, that come with the VM software.
For VMWare, they're called VMWare Tools.
For Virtualbox, they're called Guest Additions
You should check your VMWare Fusion manual on how to install the VMWare Tools.
Also, I'd suggest you give your VM at least 2GB (preferrably 3 or 4).
If it's still unusable, you can try VirtualBox, which is free:
https://www.virtualbox.org/wiki/Downloads
As Joe said above, you should allocate a minimum of 4Gb of memory to the VM, and I also recommend that you create it with a pre-allocated instead of dynamically expanding disk, as the latter is very much slower for disk performance. I also highly recommend placing the virtual disk on an SSD
