New to CC3, have a few questions
Hello all,
I recently purchased Campaign Cartographer 3. The program is quite powerful but not so easy to use and the manual is not by any means complete.
Anyways, here comes the questions:
1. If I want to make a local area map from a larger continent map. In essence, "extract" the portion of the map I want and then make a new map with that portion of the map.
2. I had borders on a map I am working on, but now the borders are gone. How do I add them back in again?
2. Did you hide any sheets or layers? The Map Borders are located on the MAP BORDER layer and MAP BORDER sheet. If any of these are hidden, the border won't be shown.
1. That guide is for CC2. I tried all those steps and it simply does not work the same way in CC3. At least I am not getting the same test in the command line for example. Also, mor importantly, nothing happens
2. Nothing is hidden. The borders are just gone. Is there any way to add them back in again?
2. The map borders are just regular polygons, so you can just draw new ones. Alternatively, you can use the
Draw->Insert File...menu choice and use it to insert one of the existing templates into the drawing. You will then need to delete any background image and scalebars/compass roses present in that template.The templates should be hanging out in the Templates subdirectory in the main CC3 subdirectory. (Edit: The Insert file command seems to not like to insert *.fct files [template files], so you will need to copy the desired template somewhere else, then just rename it to .fcw [CC3 map file] instead.
CLIPCOPY, select enties, select origin (0,0) by default then go to the new map and Ctrl-V, select insertion point corresponding to the origin point.
