Download speed
                    Just ordered Character Artist 3. I know it's a large download, but I'm being told it's going to take upwards of 14 hours to download. I've got a pretty fast connection at this end, so I'm just wondering if this is normal or not.
I know fast connections cost money and Profantasy isn't a huge company so maybe the speed I'm getting is what I should expect - if so, fine. I'm just asking in case there is something wrong, because if there is, the sooner I ask, the better.
~Dogtag
Now to see if it unzips and works
"Unexpected end of archive"
I'm not impressed. I was planning on using the software today.If I have to redownload it all, at the speed I had last night, that's not likely to happen.
I originally downloaded the web installer to see how it would work. It went slowly. Then I downloaded the full, 3 GB, installer in about 15 min +/-.
~Dogtag
I keep getting 'network error' after 20-30 minutes of super-slow download. I tested other sites in the US and UK and have top speed satisfactory downloads. Also video streaming etc is fine. It just seems to be when I try to download my three purchased items that I enter slow motion mode.
I have tried only downloading with nothing happening in the background, no surfing etc, but this still leads to eventual network problem or failed download.
After a day struggle (constantly resuming downloads that failed) I managed to get CC3. I am now many hours into trying to get past 400meg of DC3. I am tearing my hair out with this. It cost 130 NZ dollars so really dont want to spend more on some program to help me do what should be a standard download.
I there other sites other than the one i got in my purchased items list to download from?
Can we get a digital copy on a disk or something? The postage time would surely be less than this download (plus I am burning up my internet cap with each failed download).
Sorry to sound like i am grizzling, but this is so frustrating.
Please can anyone help?
I suggest you contact ProFantasy support. They may have an alternate download location, or some other way to help you.
Great. Remember to post your creations in "Show and Tell" when you feel ready.
I took the plunge and bought character designer too.
Oh dear, same download problems again. Super slow, crashed several times... now, days later i got a full download. When i try to run it, it stops at 70% and says "You should download a new copy as it may be corrupt or your password may be incorrect" or something to that extent.
Any change of hints on why this might be?
Check the file size and file hash.
The file size should be exactly 2 812 335 376 bytes long.
Using Sha256, the file has should be C6352455B37AF4143AA1F9BF15964CC485BFB233FA8C56863C0584E2472C82D4. You can find this by running the Powershell command
Get-FileHash -Algorithm SHA256 .\CA3SetupForCC3Plus.exe, and you can automatically start powershell in the correct directory by having a file explorer window open to the directory you have the setup file in, and then select Open Windows PowerShell fom the file menu.If any of these doesn't match, the file has been corrupted during transfer. (I grabbed a new copy myself just now, to make sure I got the exact same version as you.)
I will post my internet speed benchmark followed by my system specs under this, so you can better understand my position.
I have gig-speed fiber access with the following speeds:
To test your download speed, ignore any sggestion to test between your computer and your ISP. Go for a nearby city instead.
http://beta.speedtest.net/
That site will give you your speed out to the Internet. I supposedly have 100 gigabits speed, but it seldom goes above 65 gigabits and is more likely to be 15 to 25 gigabits.
May I thank you, you have accurately described my EXACT situation also, albeit in a much more accurate and less grumbling manner than I did. I ended up getting the three pack running. But it took several days and happened exactly as you described. I am currently having problems installing the Character Designer.
The software is fantastic, it's the process in getting it downloaded and running that I am finding challenging ;')
I can't really say why your downloads are slow, as mine are blazingly fast.
I traced my actual download location, and it is from a server in Virginia, USA (hosted by Amazon.com). I am in Europe myself, so I doubt there are any other server locations, since if there were, I would certainly have been sent to an European server instead of the US. But still, even here in Europe, the US server is very fast, and downloading the full CA3 setup only takes me a few minutes, and it is definitely not because I am close to the server, as it is half a world away.
Nate's case is especially curious, since he is just one state away.
