World Map settings
I'm getting ready to map a world map for my campaign. I've got a sketch of the main contenent that my adventures will be on. Other landmasses are not as critical in their size and shape.
My question is, is there a setting for a new map in CC3 that is designed for world-scale maps?
I recently got a copy of Fractal Terrains and was going to use that but it only exports to CC2 and that's not the style I want at all. Is there an option to export to CC3 styles?
- Go to Save CC2 File
- Create
- Unselect Temperature Contours, Rainfall Contours and Climate Contours
- Click Next
- Under Contour Settings unselect both Draw Filled Colours and Draw Contour Outline
- Keep the Coast line selected
- Click Next
- Select YOUR preference of detail
- Click Next
- I normally only select the border
- Click Next
- Name your style Like Lined etc.
- Now save as a CC2
You may have to play with the settings, it has been months since I've done this and a reformat of my harddrive also since I've done this, so my original settings are lost.- Next open with CC3
- You may have to explode then place them in the proper Sheets and layers.
If your using a large scale campaign world this is a great way of making maps from different areas and keeping the scale proper
