Edge Fade Inner not working
I have installed CC3+ to the latest edition and for some reason my edge fade inner command simply does not work. It won't even load when I click on it. The other thing that is I never really thought about before was that I have two edge fade inners. Should I have that many? I also have the Vinteri, Bogie and CSUAC 2 installed all latest versions as far as I know. Is their a fix for this that I can't find?
I'm not really sure about what the problem might be but here are some things you can try.
First, you might want to try typing this into the command line at the bottom of your user interface: SELBYD
If that doesn't work, try running a repair on your program.
Those are the only things I know of that might help. Monsen or someone else may come along later and give you more clear advice but I'm not sure when Monsen will be back on as it is probably really late at night or really early in the morning where he lives.
