Weird Artifact with exporting map
Hi Everyone, I am trying to export a map in high resolutino using save as then png or jpg at dimensions 8000x8000 (I made the map at approximately 500x500). When I export it at this resolution I get this weird white spot in the top right hand corner (see image 1). However, when I export it at a lower resolution the white spot moves (and gets worse). See image 2.
Does it look like that on the screen when you are working on it?
- selecting the edge of the white area to see if its actually a white polygon of some kind
- switching sheet effects off to see if it still happens
- if its a sheet effect - checking that all effects are set to 'map units' rather than % of view, or any of the other options
EDIT: I don't think its a polygon causing the problem if you can't select it. I think its one of the sheet effects
I can check out the effects if you would like, but you will need to upload a copy of the FCW file here so I can download it just to see what's going on with it.
If you upload the file I'll see what I can do with that white polygon for you. There's a possibility that there's a sort of fold in it. I can try to sort it out for you?
Its incredibly easy to do - especially if you are working with lots of white polys on a while background (my eyes went a bit crossed before I managed to work it out), but to prevent incorporating anything you don't want in a mulitpoly in the future hide everything else first, and then just before you ok it check to see how many objects are selected in the command line. There would have been 3 rather than two in this example - its just that you wouldn't have seen it with everything being white.
Let me know if what I've done has solved it will you?
Thanks
When I start a new map each time I tend to delete the frame lines straight away - just to prevent that kind of thing from happening. But if you do that you also have to be careful you don't delete the border that hides all the things that fall outside the map at the same time.
The map is going really well, btw - I got so carried away with solving the problem that I forgot to say!
I also tend to hide the background sheet and change the window color to a light green. This can make spotting odd stuff easier.
That is found under view > view-window color > right click > select a color from the selector and click ok.
