Making your own interactive atlas to give away to others
Hi.
I have a product question about CC3+ and its ability to make an interactive atlas.
I was wondering if anyone knows how this works with CC3+. Is it possible to make maps in CC3+, make them into an interactive atlas, and then send the atlas to someone in an email, and have them be able to open up the maps and use them as an interactive atlas without the person who received the maps needing to own CC3+ as well?
Thanks
Thanks
All CC3+ maps require CC3+ to view. The free viewer doesn't support CC3+. Well, it would work on pure vector maps, but not on maps containing raster artwork.
You could make something similar by exporting all maps to image formats, and then use html to make image maps to make clickable areas in the images, but that would have the usual limitations images have compared with native CC maps.
Thanks for the answer Monsen.
The globe program that I did for the Forgotten Realms Interactive Atlas, for example, is pretty much trivial to do these days in a browser using leaflet.js; you do need to generate the XML to hook everything together, but that's not hard to do.
FT3's multi-file export uses fairly primitive HTML to link the multiple maps that it outputs.
You'd need to learn some bits of other technologies to get everything to work.
Realm Works lets you load in the map, pin it and connect the pins to articles where you can write what ever you like.
Now this gets better... because this is about to happen...
Soon (as in Feb 2017) they will launch the Content Market. They have already released the ability to Import and Export realms. Which means you can already share your content with whomever you like and even better, when the content market launches, you can sell it.
To give you an idea of whats possible. This is an interactive map of Faerun that I've been working. And before anyone else asks... no you can't have it due to copy-right.
@Sklore: Cool. I've got Realmworks but I haven't been keeping up on it. I've been working on my Asian based world there but it has been a while. Nice to see they are finally getting things back together after their main content person left.
