RPG campaign world building project
As yet another new user to both FT and CC3+, I have a question about how the two programmes interact and how to work on scanned handwritten maps.
I am aware, that related questions have been asked before, but sadly I have a hard time understanding the answers, so I will try with a different line of questioning.
The project in short is to start off the campaign by creating the world, we are going to play in. The players will take on the role of gods and in a session of play, sculpt the world with sand, paint, play dough and the like. We will end up with a rough looking physical, 3D landscape. My thought is to take a picture from directly above the model and try to work on it digitally, filling the low points with seas and making the high points into mountains. Ideally, FT would handle this. The function of partitioning the world map into smaller maps would help me greatly.
The question is: how do I import the picture of the physical model into FT? Is it at all possible? Do I have to go through another program?
Note: The final result doesn't have to be accurate. The model, we will create, isn't a precise model of Creation. It is the gods' first rough draft, so the end result can be very different from the model. It's all about the process :)
Thank you for your time.
    Have you considered just having a computer on the table with FT on it and let your players interact directly with it during the session instead? (Either controlled by you on directed by the players, or just assign the mouse around)
    You can import into FT3 based on height data, but a picture of a sculpted landscape would hardly count as that, and would require quite some work to prepare. One way to import is to use an image as a base which have different colors for each height contour in the map, but your photo of the model would need to be heavily pre-processed in an image editor to make something like that from it.
  • Thank you
    The idea with having the computer on the table is beautiful in it's simplicity. I actually hadn't considered that. I will, however, try to rule out the other options first, before resigning to that solution.
    As it is connected to one of the basic koncepts of the campaign, I am still interested in trying to import some sort of handmade model. The idea is to collectively design a sigil or glyph, which is the central symbol of everything. I would like that symbol to be reflected in the landscape of the world.
    What if I import a simple 2D drawing. Would FT be able to make a map out of that? Could the program fractalize the edges and create som sort of topography out of the rest?
    What if the model was painted in different colors, that could be interpreted by the program as height contours?
    What kind of pre-processing would that entail? Unfortunately it is not within my means to purchase photoshop, but I have GIMP 2 and am currently struggling to make use of it.
    (and thank you for the swift answer)
    edited November 2016
    Now, there are many ways of importing things into FT3 (A popular option involves going through Wilbur, which can import a bunch of formats. Parts of this tutorial may be helpfull.)
    Posted By: OrmedrengWhat if I import a simple 2D drawing. Would FT be able to make a map out of that? Could the program fractalize the edges and create som sort of topography out of the rest?
    Yes. but it needs to be a greyscale image with black indicating wholly water, white wholly land and greyscale the inbetween.
    Posted By: OrmedrengWhat if the model was painted in different colors, that could be interpreted by the program as height contours?
    Yes, but it needs to be solid colors, as you must assign one height value to each unique color. I've attached three pictures to this post (fetched from the Tome of Ultimate Mapping) which shows an input and the result of this.
    [Image_7046] [Image_7047] [Image_7048]
  • As someone who attempted this recently with my own campaign world. There are some shortcomings.
    With importing the image I made through the lengthy process from an image, then converting to greyscale, then into wilbur and finally finishing in Fractal Terrain. I found that the input image no matter what I tried would not give me the breadth of altitude that should of been possible.
    With Fractal you can get as a default -30 000 to +30 000 feet. Yet no matter what I input for my image it would not get into these parameters.
    The program is pretty good but there are some major failings.
    I have found you cannot manipulate climates. Every setting is based on realistic mathematics. You can make changes to altitude, rainfall and temperature. Those in turn manipulate the climate. So not very good for creating a fantasy setting where other factors could come into play.
    The manipulation of the map itself is difficult to be precise even when using a mask selection. For an example I wanted a plateau as one of my countries. I could find no way to manipulate the selected are to give me a smooth elevation in that region. I tried a multitude of brush styles and settings.
    With all this being said, the best option is to keep randomly producing worlds until you get one that is close to what you want.
    Exporting the map is a pretty cool feature, but not wholly perfect. It takes massive work if you want to have maps that represent the countries and not just the precise segmented regions that are produced. I have yet to try attempt making the regions into country maps.
    I outputted into 275 maps and it took me a week to label down four layers of the map with country names and backwards links to layers above. So it is a massive undertaking if you go for a lot of maps.
    Posted By: cobra mustang
    Personally, I don't do the mass "multiple files" export, I manually pick what to export each time, zoom in, and export that view to get precisely the region I want. I find that the multiple files export just gives me a lot of maps I don't need, or are divided weirdly from what I need.
  • Agh!
    Next problem: I can't seem to get Wilbur to work properly. After I install it, it simply doesn't turn up. I'm using Windows 10 - is that the issue?
  • Thanks for the input, Cobra Mustang.
    That will save me a lot of hassle :)
    Guess I will go for another solution :)
    Works fine for me, but doesn't seem to create an entry in the start menu, so you need to start it from the installation location.
  • Yes I used windows 10 also and I also hadd a problem finding the proper version in my directory.
    This is where I found mine. There were two different versions of wilbur but this was the one that worked. I do not recall if I used it in a previous version of windows though. I may have it running in windows 8.
    "C:\Program Files\Slayton Software\Wilbur 1.85 (64-bit)"
    Posted By: Monsen
    Ooooh that is a great idea so I can try link my text bodies to full country sized maps. I may have to give it a try, thanks for the suggestion.
