Small bug with metric template (SS4)
Hello,
I think I've encountered a small bug with the metric version of SS4 (dungeon of Schley). I just draw some vegetation, and when I activated the effects, the trees started to cast a huge shadow. After looking at the effects, I could see that the shadow was 10 map units (ie 10 meters) long. Then I looked at the non SI template, and discovered that there, the shadow was still 10 map units (but there, it means 10 feet, which is more reasonable).
Is there any way to export effects in a textual format, so that I could compare those and check if other corrections should be done?
There is no way to do a textual export of the effect settings. You'll have to open two instances of CC3+, with one type of map in each and compare them sheet by sheet. Though I would probably not bother with that and just see whether anything on the final map looks out of place.
Ralf: Currently, it's possible to enter effect dimensions in map % or in map unit, which is really fine for overland maps, but I think that for dungeon maps, it would be quite interesting to enter some effect parameters in real world units too, which would make adapting to metric system a no-op.
