Importing bitmap fills - Create other resolution - Red X nightmare
Lorelei
Betatester 🖼️ 46 images Mapmaker
So....I have NO idea how or why i had the "create other resolutions" box checked while importing bitmap fills on the map i was working on last night. NOW it makes sense that it seemed to take extra long to import the fills....now i know why. Apparently when that box is checked it creates various resolutions of the fills in the folder you are importing from - great you think. NO. While creating L, H and VH res fills is nice, it RENAMES the original file, therefore giving me the infamous RED X's in almost all my maps that i now open because all my bitmap files in my folder on my desktop have been renamed by CC3!!!! What a nightmare. I have to go in and RENAME everything again.
So...word to the wise....do not have the Create Other Resolutions box checked if you have used ANY of the files in that particular folder in any other map, or you'll have red x's everywhere, too! I think....i you then check the Copy Folder to: box perhaps it creates a new folder??? I don't know, but damn this is going to take forever to fix as there were soooooo many fills saved in that folder! Lesson learned.
The copy to folder is also recommended though, as this creates a copy in another folder and renames those, instead of your source files.
By sheer coincidence I did it earlier today when I was trying to include a new stone texture in my personal collection. Fortunately I only had about ten affected patches to sort out. I didn't change the filenames back, but updated the affected fill areas with change properties.
When you find a map with a red x fill in it, open the fill style dialog, go to bitmap files, find the offending fill (It will have a red x in the list as well, so it should be easy to find) and change the reference from the old one to any one of the four multi-resolution images. This updates the map to take advantage of multi-resolution fills at the same time as you are fixing it.
It may be down to the fact that the fills list is a complete mess. I have about 100 empty slots in there...
This is also a medium sized file by Ralf's reckoning (I've sent it to him before for another reason). It has about 100 sheets and is the slowest file I've got. Do you think that is why it crashes if I try to reassign a fill style?
EDIT: As a side question on the same topic - Is there a way to purge all the empty fill slots without having to do them one at a time?
As for crashing, it might be, but difficult to say something conclusive. All the effects in city maps usually causes a load on CC3 though, so try turning off effects before working with the fill style. Sometimes, it can also help zooming into a blank spot on the map, simply because if it isn't on screen, CC3 doesn't have to update it. You can also try hiding all sheets.
