UPDATE: Bogie's Objects & Update 8
Vintyri
                Traveler
                    UPDATE:
Since my original posting, CC3+ has gone through Updates 7 and 8, current at the time of this writing to Version 3.74.
Beginning with Update 7 (Version 3.73) CC3+ implemented a new and better multi-resolution system for the graphic icons in toolbars. As a result, a number of users (see postings below) had to update the icon sets that we delivered with Bogie's Mapping Objects 1.0. Today (Sunday, July 24) we updated the installation sets to automatically install the new icons. The only special steps that one now needs to do are:
1. Copy the file FCW32.mnu from (DataFolders)\ProFantasy\CC3Plus to a temporary, non-CC3+ folder.
2. Install Update 8.
3. Copy the file FCW32.mnu from the temporary, non-CC3+ folder back into (DataFolders)\ProFantasy\CC3Plus, overwriting the version that is there.
These steps are necessary because Update 8 overwrites the extended overland toolbar that you now have with a new version that has only the basic icons. This copy operation will restore the extended version.
For those who wonder whether they downloaded before the new versions was available: It has been online since 1 p.m. (13 hours) on Sunday, July 24, 2016. That's 12 noon London time and 7 a.m. New York time.
10. Copy the backed up files city.mnu, dungeon.mnu and FCW32.mnu back into (Data Folders)\ProFantasy\CC3Plus\
Unzip the attached file into (Data Folders)\ProFantasy\CC3Plus. Let me know if this fixes the problem.
However, that just tells you what's up. It doesn't help you do anything about it. To help you, it might be a good start if you told me which Vintyri file(s) you downloaded.
I lost my toolbars when I installed Bogie's final release, and you sent me the toolbars. You've just gone through the instructions to set the toolbars back up after installing update 7. In my own garbled way, I was trying to ask if I was going to need to go through this process before installing the update, or if I have the updated toolbars, and can just install the update without going through this process first.
1. Close CC3+ if it's open.
2. In the Windows (File) Explorer, go to:
3. Make a backup copy of the file FCW32.mnu that's in (Data Folders)\ProFRantasy\CC3Plus. Pu this backup copy in a non-CC§Plus folder. We're doing this because Update 7 will overwrite your FCW32.mnu with the basic version that doesn't have the CSUAC, Bogie of Vintyri toolbars.
4. In the Windows (File) Explorer, go to:
(Data Folders)\ProFantasy\CC3Plus\Bitmaps
5. This folder contains two lower level folders named "Icons" and "New Icons."
6. Rename the folder "Icons" as "Old Icons"
7. Rename the folder "New Icons" as "Icons"
8. Copy the backed up file FCW32.mnu back into (Data Folders)\ProFantasy\CC3Plus\
9. Reopen CC3+. You now should have the new and improved icons in your toolbars.
When you get a chance (I'm in no hurry, I downloaded the update and can take care of this at any time) I just need to know when in this process I install the update.
You two take care, and be safe!!!
And I'm happy to hear you and your family are okay.
For more information, go here:
http://forum.profantasy.com/comments.php?DiscussionID=6230&page=1#Item_1
Reason?
Also curious as to where to obtain CC3+ update 8, as it is not available in the CC3+ Updates list.
Thanks.
I just started a thread about Update 8, and received a reply.
To get update 8, go here:
http://forum.profantasy.com/comments.php?DiscussionID=6237&page=1#Item_26
