How to UNDO the latest update
Lorelei
Betatester 🖼️ 46 images Mapmaker
Ok, so i have no idea WHY this is happening, but at the moment i need it to go away. I did the latest update minutes ago and not my program is first, the program is opening and responding VERY slowly and glitchy, then at first i thought i lost my Bogie and CSUAC symbol menus but i found them...i did however, lose my Character Artist Menu and Perspectives Menu on the toolbar. This will not do. Aside from a system restore, of which i am prepared to do if necessary as i created a restore point before the update because, because, well honestly i don't know why, i usually dont but something made me do it and right now i am grateful. But is there another way to undo the update? I know this sounds naive, but as i've said before....i REALLY don't know much about computers, software, tech and lingo
I am sorry the update is causing you problems, but it does contain several important fixes, especially for perspectives), so I think you should focus on getting things working with it rather than removing it. From previous posts, you also had some other weird problems, so I believe you should really run the newest version.
The slowdown is definitely weird. I am not experiencing anything like that with the update. Have you tried restarting your computer, that clears up any hung processes. Additionally, try running the update again (select the repair option if it asks you to repair or uninstall).
(I need to go to bed now (it's 4am here), so I won't be around to answer follow-up questions unfortunately, but there should be other people here who can help, and if not, put in a tech support request, and I am sure Ralf will get back to you within a reasonable timeframe)
There's no guarantee these will help (sorry), but they may be worth a shot.
Good luck!
~Dogtag
1. Be sure to temporarily disable the anti-virus program and use the "Run as Administrator" option, as Dogtag already has suggested. There have been a few times when I forgot to do that and got an installation that seemed to work perfectly but had lots of things missing when it was over.
2. Run the Update file again and pick the Repair option.
If that hasn't fixed the toolbars, go into your CC3+ data folder (not for CC3, only CC3+) and run VPToolbarFix.bat. It was installed along with Bogie's Mapping Objects. It will rewrite and correct your menus and toolbars, if there are problems in the menu-toolbar code. However, it won't help you if the toolbar-menu problem comes instead from problems in the program code.
Try running CC3MenuConfig.exe from your CC3+ program data folder to get the menus back in shape. YOu can also do a repair install of the add-ons with the missing menu icons. None of that should affect your CSUAC and Bogie tools.
A real backup program will get everything, but I understand that it's a real PITA to spend that much time and space on things you might not care about.
Oh, I take that back. After about four minutes frozen it finally began installing. About to run it.....fingers crossed and.....success. And, mark nothing happened to my toolbars. They are there and intact. Should I not copy the fcw32.mnu back and leave well enough alone?
Hmm... not doing it on my install now, but under CD3, some of the roof tiles took well estimate 10 seconds to load. But its not doing that this morning.
