Delete hyperlinks between maps
Please can someone tell me how to delete a hyperlink in CC3+ without deleting the object to which it is attached?
Thanks
Thanks
Once you show them, you can select them and then modify them. That is, you can move, resize, copy, or delete them like any other entity. You can't rotate them though, because they must be rectangles along the X-Y axis. Sometimes, however, hotspots might be partially obscured, even when they are visible.
An easy way to select them is to do the following:
- Click Delete and then right-click to bring up the pop-up menu.
- Select Entity Type near the bottom of the pop-up menu.
- Check the box for Action: 2d hotspot and then cilck OK
- Ctrl+Click any hotspots you do not want to delete.
- Right-click and select Do It.
Voila!A list of entity types displays.
CC3 selects all hotspot entities on the map.
The hotspots are de-selected.
Note: The "Entity Type" selection may be persistent, meaning it remains until changed. I usually immediately follow with a Change Properties command, select by type, and then de-select my recent selections, just to clear the list. This may not always be the case but it's happened to me enough that I do this just to be sure.
I hope that helps,
~Dogtag
EDIT: Shessar beat me to the punch!
I can now get on with the other three maps, only this time I won't be taking a whole afternoon over just one of them.
Thank you very much :-)
I am so glad topics are not parsed from this Forum. I looked through theTome of Ultimate Mapping manual and this wasn't in there.
Is someone going to work on adding this kind of stuff into the manual for CC4?
While the tome doesn't address deleting them directly, it tells you how to show/hide and edit them on page 136.
I try to cover as much as I can for the documentation, but CC3+ is pretty complex so it is difficult covering all the different ways people may be looking for information without making the documentation unwieldy.
But I am always taking suggestions for what to improve.
