CC3 Dimensions
                    In CC3, is the largest dimensions 1000x800? I would love to make it larger but it wont let me. I use the Overland Maps and also choose decide settings my self. I did try symbol catalogs and it said I didn't have to have any limit for dimensions. Well, it simply is doesn't work too well heh. When first used this and still use this method, I actually use several 1000x800 canvases to make my maps. I would love to have one huge canvas for a map instead of using multiple ones and then editing it photoshop. I don't mind doing that but if anyone can lead me to the right direction where I can use CC3 symbols and Symbol Set 1 as well with a larger dimension, I would really appreciate it =D
Also I noticed some of my maps are not like what everyone else produces it seems =p. If you like, I have 6 really good maps I could post if anyone wants to see =D
Pick the closest template to the size you want. If you want a really big map, for instance, pick the 10,000 x 8,000 template.
Then unfreeze all layers, and freeze the Merge layer.
Then type SCALEXY, select "All", and modify the X and Y dimensions by the amount you need to get the map size you want.
If you want a map 30,000 x 40,000, for instance, you'd multiply the X dimension by 3 and the Y dimension by 5.
Freezing the Merge layer ensures the scale bar doesn't get resized. You can skip that step if you plan to delete the scale bar and replace it with a different one.
Then to restore things back to normal, unfreeze the merge layer and freeze the map border layer.
I'd like to see those maps you've created.
If you don't see any templates at all other than 1000x800, you should take a look in your CC3\Templates\Overland Maps directory to see what is in there. If you only have 1000x800 templates, you'll probably need to reinstall CC3.
The method for resizing templates described by DarrenHill above works nicely even if you don't have an appropriate template though.
Once you have typed the command, followed by enter or space, you will see it will start asking for several parameters down there, which you must input to finish the command.
2. Open up the Layers dialog, hit "show all" and "thaw all". Close the dialog
3. Open up the sheets dialog. Hit "Show All". Close the dialog
4. Make sure no dialog boxes are open on the screen.
5. Type in SCALEXY. The command should appear in the command line at the bottom. Hit enter.
6. A prompt now appear, asking to select entities. Hit the a key to select all, the number of selected entries should now show 10 or more entries, depending on the template. Then hit the d key for done.
7. It should now ask for the X Scale. Assuming you started with a 1000x800 map, enter 15 here to get your desired size, then hit enter
8. This time, the Y scale. Again, to get the correct scale you are asking for, enter 18.75 here, then hit enter (18.75*800 = 15000)
9. Now it asks for scale center. The default is good, so just hit enter.
10. It should now be resized, but you need to redraw to see it properly. Hit the redraw button and you should notice the map is now significantly larger. Hit zoom extents to see the entire map.
0. Just in case you forget, thaw the Map Border layer, and optionally, freeze the Merge layer.
1. Rightclick the Scale button, to get the following list of options:
and left-click Non-Visual ScaleXY.
2. Then, without selecting anything, right-click, and you'll see these options:
Left-click "All".
Then right-click again to get that list back, and click "Do It".
3. Now, look at the botton left of the screen, just above the start menu (assuming CC3 is maximised).
This is the command prompt.
It's asking how much you want to multiple thye X dimension. You can either right-click to accept the value listed, or type a number and press enter.
4. You'll then get a similar message, asking how much you want to multiple the Y dimension.
Again, right-click to accept the default, or type a number and press enter.
5. Now look at the command prompt - it says: "Scale Centre [0,0]" (well there are a lot more noughts).
Here it's asking you for the centre of scale effect. Just rightclick to accept the default.
6. And that's it, it's done.
But it's helpful to see alternate descriptions of the same process.
Two different explanations for the same thing never hurt though. I see you went the mouse route, while I went for keyboard commands. It's one of the many things I love with CC3, you can use multiple approaches to do the same thing.
Say you are using a template with a dimension of 800, and you want it to equal 15,000.
You can type:
15000/800
and hit enter, CC3 will perform the calculation for you.
Anyways I did get it to work. Last and final question. How do I know what to put into the x and y for the different sizes i want. Say i want an x of 4000 and an y of 3500. Do I simply just put 4000 in the x command space and 3500 in the y command space? How did you come up with the number 15 and 18.75?
As DarrenHill said, you can just enter the calculations directly into the command line. Instead of calculating that 15000/800 = 18.75, you can just enter 15000/800 directly at the prompt (scale equals new size divided by old size)
Do remember that CC3 does not actually have a fixed canvas size at all though. The dimension listed for any given template is basically just the size of the drawing that makes up the template. You can draw outside of this area if you wish (That is why the resize trick in this thread works so nice, since no matter what template you use, you have basically unlimited drawing space).
