Map symbol bar minimized
This may be a silly question. Somehow I've managed to minimize my map
Symbol bar. It's currently unusable. But I can see it's still there.
How do I fix it? I'm having trouble posting a picture of it.
    You mean the symbol catalog window? From your description, I am a bit unsure exactly what is happening, but first of all, click the little hammer icon down in the bottom right, and make sure the symbol catalog window is actually turned on.
    Then, make sure to restart CC3 and also try another menu set by switching to another add-on if you have. Sometimes, the GUI can get a little stuck.
  • edited April 2016
    The screen looks like this. The symbol catalog is on. I reall y appreciate any help.
    edited April 2016
    I notice that your symbol catalog window is also on the wrong side of the screen. Issues like that usually happens because your registry entries are missing or corrupted.
    I've attached a registry file, it should restore the relevant registry entries for the symbol catalog window. Note that you may need to turn back on some of the toolbars after running the .reg file.
    As always when you dowload a .reg file from the internet, please open it up in a text editor like notepad and examine it before you run it, to prevent any malicious entries, and never run a .reg file you don't completely trust.
    Also note that if those registry settings are corrupted, there may be others as well. You may need to reinstall the program.
  • Thanks for your help. I really appreciate it. ?
