mirror a sheet
RobertR
Newcomer
I would like to mirror the entire sheet horizontally. I go to edit>reshape>mirror but can't seem to get it to do the whole sheet.
Thanks
Robert
Thanks
Robert
Also, the Mirror command "flips" the selected entities to a mirrored position. That is, the items you select are moved and flipped. If you want to create mirrored copies you need to use the Mirrored Copies command. You can right-click the Copy button
Sheets are not generally available as a "selection" option. Layers are generally used for grouping/selecting. That's not to say you can't do it, it's just that it probably isn't something you can choose from the selection options. To "select" the sheet, try hiding all sheets except the sheet you want to mirror. Then, choose the command you want to use (Mirror or Mirrored Copies), select all visible entities (they should all be on the one sheet) and then execute the command.
I hope that helps, but then I've been up for 26 hours so I may not be as think as I clear I am.
Cheers,
~Dogtag
