About Cartographer's Annual 2008
The banner at the top of the Cartographer's Annual 2008
sub.profantasy.com/2008/index.html
has a 3D line drawing of a city that looks really cool. Can anyone tell me is that set in the 2008 Annual or is it somewhere else?
BTW There has already been a forum about CA
Here is full version of the map:
Shows that you don't need to have colour to make a good map.
This means that there are basically two options:
1. Draw the swamp way bigger than it is supposed to be, then use the SCALE command to change the size of the entire swamp afterwards. This will also change the scale of the fill.
2. Create a smaller version of the Hatch style.
To do this:
Default Terrainbutton to bring up the drawing tools, clickAdvanced, Select "Terrain default, Swamp" from the list, clickNew, give it a new name, like "Terrain Default, Swamp Small", HitOutline, hitProperties, then change the Hatch style to the new style we made "CA20 Swamp, Small", clickOkto you get rid of all dialog boxes and return to your map.The December issue will be about relief shading for mountains.
Pat
So while the examples of the preview page aren't done in CC3, I'm sure that what ever Ralf comes up with will be amazing.
