Installing John Roberts Dungeon Pack at CC3+
                    Hi,
trying to install my first dungeon pack, but it does not work out yet. I got CC3+ and DD3 and CD3 installed. I tried to install this free john Roberts dungeon pack from 2011 (issue 54) and the free battle tiles (issue 36B), but they are not available in the software.
I figured out that they were probably installed in the wrong place - AppData, local, temp instead of programm data, profantasy... - and I moved a folder manual - John Roberts Dungeon Tiles - but I still cant choose the John Robert Map Style when I create a map. There are no install options where I could change the install path. So no idea what to do now.
A workaround would be to open the symbol cataloge manually
- I relocated all the folders with John Roberts PNG files at some easy to remember place.
- I openend a random new map in DD3 with the settings: Dungeons / DD3 Dungeon
- I imported the floor tiles of the john robert pack and selected the Floor layer, I used the "update" and the "rebuild all" option alternatively
- I could see the imported floor tiles in the symbol manager but nowhere else, I can't select them if I use the "Floor drawing tool"
So this ist where I am right now, I basically just want a way to add all the extra designs so I get more variety in my maps. Any help concerning this problem or suggestions where I can sign up for some university degree to get the grasp of this software is higly appreciated :-)
Additionally, drawing tools don't magically appear. If you wish to have drawing tools utilizing the newly imported fill styles, you need to create them (or modify the existing ones)
