Unable to install Annual (vol 7) using CrossOver (or on Windows)
Hi all, I'm running CC3+ on Mac using CrossOver. I installed the core app using default settings, which works fine. I'm attempting to install the vol 7 Annual by double-clicking the vol 7 exe (opens in CrossOver), selecting the bottle that has CC3+, then installing. Installer fires up to the intro screen, but when I click Next I get the following and it terminates.
Can anyone help? Thanks...
EDIT: Same thing happens if I "Run As" Administrator on Windows.
EDIT #2: Found this support article, but my registry keys in both Win and CrossOver look fine. Opening/saving/exiting CC3 doesn't help either.
Not sure what the problem is, as other people seem to be fine running with CrossOver (and CC3+ works fine also). I'm on a 2013 MacBook Air.
Profantasy is in the process of converting the older Annuals to work with CC3+.
